Erste Plastikbälle genehmigt
- mynamenotbob
Es beginnt...
Zurück zu den Wurzeln!!!
Holz: Tibhar CO<S<3 (neue Version) | VH: Friendship Focus III Snipe 2.1mm | RH: Tibhar Grass D.Tecs OX
Re: Erste plastisch Bälle genehmigt
Ich bin echt mal gespannt ... trotz oder gerade wegen der viele Kritik und Diskussionen.
- Defensiv-Anti
- TTR: 1600
Ich hoffe einfach das ganze Thema noch möglichst lange verdrängen zu können. Sonst werde ich bloß sauer.
Hier gibt's ein paar Infos vom 26.12.2013:
"Seamless Plastic Poly Ball
A month ago I had ordered a packet of the new poly balls, the non-celluloid seamless plastic ones. As I blogged previously, they weren't really acceptable. However, Kagin Lee had several of a newer version (Xu Shaofa balls, also seamless) and he let me and others try them out. Verdict? These ones are usable, and only subtly different from a regular celluloid ball. Even the cracked sound is almost gone. I had several of our junior players try them, and they also said they were usable. One had said of the earlier version, "Unacceptable but fun to use," but these passed both his and my test for usability. So I think this problem has been solved.
NOTE added later: I also compared the ball to a Nittaku 3-star, and found them the same size, unlike the previous poly balls I'd tested, which had been slightly larger. I also bounced them side by side, and found the new poly ball had the same bounce as the Nittaku, as compared to the previous version which was faster, i.e. bounced higher. Because of ongoing arm problems, I couldn't loop with any power and so relied on others to judge how they looped, though they looked pretty much like any other looped ball."
Quelle: http://tabletenniscoaching.com/node/1692
destroy11 hat geschrieben:http://www.tischtennis-pur.de/nachricht/items/der-neue-plastikball-kommt-im-tischtennis.html
wir spielen wieter mit dem Zelluloidball!!!![]()
Ich hoffe nur, dass es ein einheitliches Verfahren im Umgang mit dem neuen Ball gibt.
Man stelle sich mal vor, dass einige Mannschaften mit neuen Bällen spielen und andere Mannschaften weiterhin die alten.
Und das innerhalb der gleichen Staffel.
Welch ein Durcheinander wäre das dann ?!?
Einen schönen Tag noch, und immer nett grüßen....
Genauso durcheinander wie jetzt auch, einen spielen Nittaku, die anderen Tibhar usw.
Wenn sie die Zulassungskriterien erfüllt haben, dann spielen sie sich auch "normal".
Spätestens jetzt kann man die ganzen Verschwörunsg- udn Weltuntergangstheorien doch mal sein lassen.
Verband entscheidet für Zelluloid oder Plastik!!! Es wird nur eine geben...tommes hat geschrieben:destroy11 hat geschrieben:http://www.tischtennis-pur.de/nachricht/items/der-neue-plastikball-kommt-im-tischtennis.html
Hier noch ein paar Infos:
http://www.ittf.com/_front_page/ittf_fu ... p?ID=34232
Weitere Informationen:
http://www.mytischtennis.de/public/Bunt ... traechtigt
"Wenige Tage zuvor hatte sich Chinas Nationaltrainer Liu Guoliang zum Thema geäußert, wie die Internetplattform Tabletennista berichtet. "Der neue Ball hat die Intensität der Rotation stark beeinträchtigt, was große Auswirkungen auf unseren Spielstil hat""
"Dr. Torsten Kueneth, Mitglied des ITTF Equipment-Komitees, beschreibt, wie sich die Daten der getesteten Bälle in den vergangenen Monaten immer mehr den ITTF-Bestimmungen genähert haben. "Am Ende sprechen wir nun nur noch von etwa einem Millimeter Abpralldifferenz oder einer etwas zu weißen Farbe", führt Kueneth aus und berichtet, dass auch die Rundheit und Größe der Bälle die Grenzwerte nicht überschreiten. Damit die Spieler die beiden offenbar doch recht ähnlichen Zelluloid- und Plastikbälle besser auseinander halten können, werden Letztere künftig mit dem Aufdruck "40+" gekennzeichnet sein."
- Verein: Torpedo Göttingen
- Spielklasse: OL
- TTR: 2020
Der in dem Video getestete Palio Ball ist glaube ich der einzige der bisher nicht zugelassen wurde von den Plastikbällen
Longsten
- Verein: SG Rhume
- Spielklasse: LL
- TTR: 1800
So wie der eiert ist das auch kein WunderMaikS hat geschrieben:Der in dem Video getestete Palio Ball ist glaube ich der einzige der bisher nicht zugelassen wurde von den Plastikbällen
Grobmotoriker
Wenn die neuen Bälle wirklich kommen, dann schüttet sie mal mit den alten in einen Eimer und macht eine eurer Standardübungen, und dann fragt euch kritisch ob ihr jeweils gemerkt habt, welchen Ball ihr spielt, und wenn ja, ob das was an eurer Fehlerquote geändert hat...
VH:BTY Roundell 1,9 mm
RH:Sriver G3 FX 1,7 mm
- Noppen Matthes
- Verein: Phoenix TTC
Zu dem Thema habe ich noch folgenden sehr interessanten Beitrag gefunden:
http://blog.kaginism.com/2014/02/a-less ... anics.html
P.S.: Kagin, der den blog verfasst hat ist Funktionaer beim USATT und auch ein internationaler Referee. Sein USATT rating ist 2050 also etwas 1700 TTR.The seamless XuShaofa ball has a different sound that I knew he would detect, so I only brought out the Double Fish and DHS balls. We countered. He looped, I blocked. He looped, I chopped. I looped, he blocked. Then I told him what was up.
Gabriel's teammate, Felipe Morita, had lost to Micaiah in the semis. (Micaiah would eventually win the Men's Singles event with a series of upsets.) Gabriel grabbed Felipe and they tried the poly balls. As teammates, each would be familiar with how the other plays, and this would be a better test than hitting with me.
The verdict? Both players agreed that when they tried the poly ball, they didn't notice anything unusual; it was just like a celluloid table tennis ball. When they switched to the celluloid ball, they noticed a subtle difference. When comparing the balls side by side, the flight of the poly ball was slightly different from the celluloid ball. But the feel of the ball on the racket was the same.
Rudi Endres
- Verein: TTF Konz
- Spielklasse: inaktiv
Und die kleinen Unterschiede wird man auch noch weg bekommen. Es wird sich nichts ändern. Vielleicht dauert der durchschnittliche Ballwechsel bei ITTF-Turnieren statt 2,98 Sekunden 3,12 Sekunden.
Das ist gehopst wie gesprungen.
Was wohl passiert, wenn man so einen Kunsstoffball vor dem Aufschlag durch heftiges Reiben am Kunstfasershirt auflädt
Mächtig konstruiert !
Jetzt wird es langsam klar, dass die ganze Jammererei absolut unbegründet war udn die Leute geben es immer noch ned auf.
http://forum.tt-news.de/showthread.php?t=107696
... ob sich da was ändert ? Hatte mir bis dato eigentlich nie Gedanken darüber gemacht....
- Noppen Matthes
Hier noch ein weiterer interssanter Test fuer ale Freunde der LN und des Abwehrspiels:
P.S.: Die Tester sind beide so um die USATT rating 2340, was so in etwa TTR 1950-2000 entspricht.
A bit busy to write more detail now but in short we're extremely happy with it.
First impression : I didn't feel it's bigger if not compared side by side.
A tiny bit heavier feel. Just me feeling. No scale used.
Info at the table play :
It has little more solid feel at contact with rubber.
Bounce - if we do blind test, more than 50% will be wrong. It has good bounce and consistence.
Sound - it sounds just like balls today. well ...a little different but not like broken-ball sound of it's previous version.
Info of testers : Me - a 2336 attacking chopper, my buddy - a 2340 or so attacking chopper. We're not pros, far from it but I think we play this game long enough to tell a good ball from the bad ones.
Chopping with it - it's great!!!! And that's all I concern![]()
