Aktuelle Zeit: Mi 24. Dez 2025, 06:42
Dr. Neubauer Rhino+ Testbericht
BeitragSo 20. Mai 2018, 05:45
Ich spiele jetzt schon seit einiger Zeit den Rhino+ und finde, dass er der perfekte Anti fuer den ABS Ball ist. Ich habe jetzt endlich Zeit gefunden einen Testbericht zu verfassen, allerdings in englisch, aber da die moisten hier wohl englisch verstehen habe ich es nicht uebersetzt. Falls jemand eine Frage hat oder etwas nicht verstanden hat so bin ich gerne bereit, dass hier im Forum zu beantworten.
Dr. Neubauer Rhino+ Review
Disclaimer: I received the rubber from Dr. Neubauer for testing
About the reviewer:
My USATT rating is currently around 1800. My strength is my forehand with which I score the majority of my points mainly through looping; I play close to the table with blocking and looping. I play with frictionless anti on backhand, mainly for returning serve and blocking topspin loops but recently also more with attacking shots.
Setup:
The Rhino+ was played with the 1.8mm sponge on Dr. Neubauer Matador and on OSP Ultimate each with Hurricane III Neo max on forehand.
I played the Rhino+ with Nittaku Premium, YinHe, Xuashofa and as in the videos below with Nittaku J-Top balls.
Description on Dr. Neubauer’s website:
RHINO+
The new Anti-Spin reference for control and effectiveness with plastic balls
Our Anti-Spin rubbers BISON+ and BUFFALO+ are among the very best rubbers on the market when it comes to the spin reversal produced.
Our latest development Dr.Neubauer RHINO+ also produces excellent spin reversal especially while blocking against topspin shots with a lot of rotation.
The rubber enables very short blocking, even on a fast blade and also against fast topspin shots.
Most of all control could be raised to an even higher level, it has become easier to find the right angle for the bat.
This holds true both while playing passively (service return, blocking) and for an active type of game through pushing, lifting and even some counter-attacking.
Our Anti-Spin rubbers BUFFALO+, BISON+ and RHINO+ are renowned to be highly effective when used with celluloid and plastic balls. However they are probably the only rubbers currently on the market that also produce good spin reversal and a low bounce with the new ABS balls.
Available with dampening sponge with the following thickness: 1.2, 1.5 and 1.8mm
The version with 1.8mm is the slowest, while 1.2mm will produce the best spin reversal.
The 1.5mm sponge version is a very good compromise.
Category: Anti-Spin
Colours: red +black
Sponge: 1.2 + 1.5 + 1.8mm
Speed: 60
Disruptive effect: 105
Control: 84
Appearance:
The surface of the Rhino+ has the same kind of a mate finish similar to the Rhino or also Buffalo and it uses the well know ABS sponge which is fairly hard and dead. Many people believe it is the best sponge for frictionless antis. The Rhino+ topsheet appears a little bit slicker than that of the Rhino or Bison out of the package due to the new coating. The only difference of the Rhino+ to the Rhino supposedly is different gluing between topsheet and sponge and the coating on the topsheet.
Weight:
I did not weight the Rhino+ but it feels similar to Rhino or Bison which I had on spare blades during the test, so generally it’s a fairly light rubber.
Feel/Touch:
The Rhino+ feels harder than the regular Rhino and the hardness lies somewhere between Bison and Rhino. I found the hardness of the Rhino+ to be perfect for my feel on the OSP Ultimate and maybe a tad to hard on the Matador blade but this is just personal preference. The new gluing seems to give the Rhino+ a little bit more direct and crisper feel which I really like.
Speed:
The Rhino+ is a little bit slower than the Rhino in passive play but develops the same speed on attacking shots. It’s possible to block hard loop drives on to the table or drop blocks short behind the net but also smash underspin balls over the table with good speed for winners. The Rhino+ has more gears than Buffalo or Bison probably due to the longer pips which give it more catapult when attacking.
Control:
I really like the control with Rhino+ and in particular that the sensitivity to the bat angle has been quite improved over ABS but also Buffalo. Especially the control on attacking shots is very good and you can even counter no spin balls. However this is still a frictionless anti and does require some practice to master strokes.
Spin Reversal:
The reversal with Rhino+ seems better than with Rhino or Bison and is still high enough with the ABS balls to force mistakes of the opponent. This is in particular true when the balls are taken very early for example on blocks or aggressive pushes against underspin. When the ABS ball is taken late it tends to loose a lot of its spin and reversal suffers.
Throw Angle:
The throw angle of the new Rhino+ is lower than Rhino and also Bison and balls tend to not to raise as much on blocks which is even more important with the advent of the ABS ball. Blocks generally stay low but also attacking shots have a low throw and tend of dive after bouncing.
Blocking:
The good control and fairly slow speed on passive shots allows for a good blocking game with the Rhino+. It is possible to blocks balls short (I believe the new gluing plays a big role here) but you can also block the balls deep with a slight forward motion during the block.
Attacking:
The Rhino+ really shines on attacking not only underspin balls but also countering no spin balls which I have not been able to do with such a consistency with any other anti. I believe this is due to the longer pimples compared to Bison or Buffalo which helps to accelerate the ball but also allows the ball to “stick” to the rubber longer. I have been working on the attacking shots lately more and you can almost use a medium pips technique to counter and smash balls. Good footwork (body needs to be behind the ball) and solid contact or necessary for this technique though. I believe more attacking is particularly important with the new ABS balls.
Conclusions:
I immediately liked the Rhino+ because it does everything the Rhino does but with better control and touch and I have been playing with it since I received it a few weeks ago. The Rhino+ is the best allround frictionless anti for me since I can do passive blocking with high reversal, drop the ball short but also attack with good speed and acceleration on the ball. This makes it the perfect anti for the new ABS ball! The Rhino+ falls somewhere between the Gorilla, which I couldn’t control to lay with it effectively, and a very slow anti like Buffalo. To me the highlight was the ability to attack, which after some practice I can now confidently incorporate into my game, and score direct winners.
Below you will find 2 videos showing different techniques and drills with the new Dr. Neubauer Rhino+ on backhand. My coach in the video has a USATT rating of 2650 and we are using Nittaku J-Top plastic balls.
1. Some drills with Dr. Neubauer Matador blade:
http://www.youtube.com/watch?v=F0pjBZPRHdw&t=238s
2. Some drills with OSP Ultimate blade:
http://www.youtube.com/watch?v=xkfh_lZxX7s
Zurück zu Antis und GlAntis
